Auxiliary fan control module
I have a 2000 SL500, and the aux fans do not work. I believe the Aux fan control module is controlled by the climate control module in the dash. I can not find anywhere the pin number at the climate control module that sends the signal current to the Aux fan module.
Can anyone shed some light on this problem? thanks very much, bb
Hi BB,
i think you mean the 2 fans in front of the radiator. They will be startet from the clima controller and 2. if the water in the radiator will be over 100 Grad hot.
[QUOTE = Mathes; 232783] Hi BB,
I think you mean the 2 fans in the front of the radiator. They will be starts from the clima controller and 2. if the water in the radiator will be over 100 degrees hot.
VG. Mathias [/ QUOTE]
Yes thanks for your responss, bb
