Zeige Ergebnis 1 bis 3 von 3
Thema: Auxiliary fan control module
    Neuer Benutzer
    04.09.2020
    Darien, Ga
    2
    Bedankt 0 mal in 0 Beitrag
    Standard Auxiliary fan control module
    I have a 2000 SL500, and the aux fans do not work. I believe the Aux fan control module is controlled by the climate control module in the dash. I can not find anywhere the pin number at the climate control module that sends the signal current to the Aux fan module.
    Can anyone shed some light on this problem? thanks very much, bb
    Erfahrener Benutzer Benutzerbild von Mathes
    21.09.2011
    Bad Malente
    1.793
    1.011
    Bedankt 641 mal in 423 Beitrag
    Hi BB,
    i think you mean the 2 fans in front of the radiator. They will be startet from the clima controller and 2. if the water in the radiator will be over 100 Grad hot.
  3. #3
    Neuer Benutzer
    04.09.2020
    Darien, Ga
    2
    [QUOTE = Mathes; 232783] Hi BB,
    I think you mean the 2 fans in the front of the radiator. They will be starts from the clima controller and 2. if the water in the radiator will be over 100 degrees hot.
    VG. Mathias [/ QUOTE]
    Yes thanks for your responss, bb
  1. Antworten: 2
    Letzter Beitrag: 09.07.09, 23:08
Stichworte
